Should be quick question
Old Oct 6, 2006 | 01:48 PM
GRHMB's Avatar
Default Should be quick question
I did not notice until very recently that the horn does not work. I hear th contacts hitting each other inside the steering wheel when pressed and I an assuming the design is similar to that of an older Mercedes. The wires leading to the horn appear to be connected but no sound. Any insight would be appreciated.
Old Oct 6, 2006 | 09:31 PM
Default RE: Should be quick question
Check for power at the Horns.
Old Oct 7, 2006 | 12:57 AM
GRHMB's Avatar
I am learning, how would I go about that? Sorry to ask multiple questions. Thanks tech
Old Oct 7, 2006 | 01:40 AM
You can unplug the horns and use a test light to test for power. One end of the test light on ground and the other in the horn wire. Then have someone push the horn button and see if the light lights up.
abzack
Jul 3, 2012 09:41 AM
elmo_allen
Jan 17, 2012 02:56 AM
777funk
Mar 17, 2009 01:54 PM
dpvovo
Feb 1, 2008 10:49 PM
volvobacon
Apr 17, 2005 01:24 AM
