Speedometer intermittent failure
Old Sep 26, 2021 | 05:32 AM
TeddyBumpkin's Avatar
Default Speedometer intermittent failure
960 estate 1992 2.3 turbo petrol automatic. Is it possible to - garage says rear sensor ok but cluster irrepairable. Does anyone know better or is the only alternative to purchase a unit to plug into cigarette lighter. When it is not working the mileage meter obviously does'nt work either so concerned about legality. Any help/advice appreciated as otherwise she is running perfectly.
Old Sep 27, 2021 | 10:02 AM
lev's Avatar
lev
It is repairable. Most likely it is the capacitors in the speedometer that are going bad and they can be replaced. They are cheap but the labor involved is fiddly and should be done by a specialty shop that specializes in electronic soldering and such.
https://www.volvoclub.org.uk/faq/Ele...eterRepair.htm
Old Dec 26, 2021 | 10:43 PM
Zombi's Avatar
Thanks for the info on speedometer repair.
gunnarsedley
Sep 25, 2011 08:58 AM
avinash
Jan 18, 2010 06:24 PM
mariotest
Dec 4, 2009 05:57 PM
va740twagon
May 20, 2009 02:37 PM
zysoclaplem
Jul 22, 2005 07:58 PM
