Strange coolant leak
So, I put another 1,800 miles on the 960 this week driving around Ca, and up to Montana, and in the process I had a coolant leak emerge. Strange thing was that the leak showed up on the first day and then never came back. It was a very minor leak, and appeared to be coming from somewhere underneath and forward of the water pump (it was dripping out of the left lower corner of the plastic cover that goes over the timing belt) I wiped everything up and then proceeded to drive roughly 1,000 more miles through traffic, hills, heat and cold, and everything is still totally dry. Could this have been some sort of freak incident with the water pump weep-hole? or is the volvo attempting to give me an early warning that something bad is about to happen??
