Strange Coolant Leak
Old Aug 10, 2012 | 01:49 PM
SHOlvo's Avatar
Default Strange Coolant Leak
I'm having an issue where I'm losing coolant from the reservoir it steams or spills past the cap. I have replaced the tank and the cap but it still steams out or spills out at hard throttle. It is not a hose I've watched the steam come out and I've tightened the cap as much as possible. Any ideas of what may be causing this? Radiator was replaced recently.
Old Aug 10, 2012 | 11:13 PM
SHOlvo's Avatar
Anyone?
Old Aug 11, 2012 | 02:48 AM
MSGTUSMC's Avatar
Check your oil for coolant. Reverse flush the cooling system. Replace the thermostat. Compression check?
Old Aug 11, 2012 | 02:55 AM
Sad to hear but here you go:
https://volvoforums.com/forum/showth...ewpost&t=63516
Old Aug 11, 2012 | 08:10 AM
SHOlvo's Avatar
Sounds about the same but there it's no oil inn the coolant thermostat and temp sensor were replaced
Old Aug 11, 2012 | 11:08 AM
SHOlvo's Avatar
Would K&W possibly work if it is the gasket?
scottp
Sep 28, 2010 12:35 PM
jsmoline
Jan 31, 2010 11:27 PM
elcs70
Apr 7, 2009 03:54 PM
zmontgomery
Sep 6, 2008 11:27 PM
timk
Nov 16, 2007 08:33 PM
