Thick white smoke. What should I do?
Old May 14, 2012 | 01:02 PM
Geoffrey's Avatar
Default Thick white smoke. What should I do?
Okay I changed my oil the other day and took it for a test drive and it was smoking white. Like heavy batmobile smokescreen. I put the recommended amount of oil but it seemed when I drained it there should have been more.
I'm fearing the worst that it's the head gasket that went but I want to flush the coolant and do a refill, I just don't know why it would run fine and then start smoking after an oil change.
Please help. Any advice would be great I want to get this car up and running
The car has 150k miles, I am doing the timing belt as soon as I figure this out. If its the head gasket I'll just do it all the same time
Old May 14, 2012 | 02:13 PM
migbro's Avatar
Did you drain the tranny and fill the engine? Believe it or not I've heard someone say they've done that on a VW.
What's the oil level on both the engine and tranny dipsticks?
Could be a failed oil seal on your turbo?
Old May 15, 2012 | 08:38 AM
ed7's Avatar
ed7
The smell of the smoke will tell you what it is.
Give it a whiff.
Ed
ArdentlyOpposed
Jun 10, 2015 08:24 PM
analogies
May 5, 2013 02:01 PM
s40sedan
Jun 5, 2011 02:50 PM
ocvolvo940t
Sep 23, 2009 08:40 PM
cool_guy_jay
Sep 27, 2005 10:35 PM
