timing marks on 95' 960
Old Feb 6, 2009 | 09:18 PM
cruzazul11510's Avatar
Unhappy timing marks on 95' 960
Hi guys, I replaced the pulleys after one got broken so I lost the position on the timing,my question is the crank shaft it rounds twice than the cram shaft,when I set up the marks how do I know if the crank shaft is in the right turn?
thanks for your valuable time
Old Feb 7, 2009 | 10:14 AM
Which pulley broke?
Did it happen when it was running?
All the pulleys have the timing marks in them. But if you didn't set it up right before putting it back on then you might end up bending valves.
Old Feb 7, 2009 | 10:41 AM
Unhappy actually I replaced the rollers
I see the three marks, two from the cam shaft and one from the crank shaft, my car was parked when I tried to start it and the roller that goes by the tensioner got broken at that time I tried to start it two times but it was not for too long my try was very short, I know the valves could bend but I want to start the car and see how much damage is on it to decide what to do, my BIG question is; when I set up the marks the crank shaft turns twice while the cram shaft turns ones;How can I know where is the right position for the mark on the crank shaft?
Old Feb 7, 2009 | 10:55 AM
Speaking in terms it really should not matter. But make sure #1 piston is on it up stroke and the mark is lined up. The valves is what makes it the compression stroke or not.
As long as the piston is up and the mark is lined you should be right.
But I will bet the valves are bent.
Old Feb 7, 2009 | 11:07 AM
Default piston up on top
when I move the 1st piston all the way up the mark on the crank shaft is not align it's like 1/4 off of a turn,
Old Feb 7, 2009 | 11:10 AM
Line the mark up at the closest to the top position.
Yes the timing marks do line up 100% to TDC they are just marks to make sure it is close.
Old Feb 7, 2009 | 11:18 AM
Default crank shaft marks
when the Marks line up the piston is like one inch lower and when the piston is up the marks are like 2 or 2.5 inches away
Old Feb 7, 2009 | 11:41 AM
Set it up that way and try to start it. But remember to turn it over by hand with the ratchet and extensions twice before trying to start it to make sure nothing hits.
Old Feb 7, 2009 | 01:45 PM
fredbyte's Avatar
Default timing marks
Go to www.stepbystepvolvo.com for free timing belt booklet on 740/940s.
Old Feb 7, 2009 | 06:31 PM
But he has a 960 with a 6 cylinder motor.
Old Feb 9, 2009 | 11:51 PM
Reverend's Avatar
Not sure if this will help you, but I tried to take decent pics of the timing marks on my B6304 when I did the timing belt.
If the link isn't visible enough, here it is again;
http://photos.robdiesel.com/viewer.p...id=144&stage=3
Old Feb 10, 2009 | 09:20 PM
Thumbs up bent valves
well well well,unfortunately the head got damage and I don't know if I Really want to fix it or just take it to the junk yard;Your help was excellent but I think I really learned that i have to be more care full with the timing belt and check it more often
Old Feb 11, 2009 | 01:05 PM
bubbaaj1's Avatar
I just picked up a remanufactured head for $400 on ebay. It came from a company out of Florida. They have a website, but it was cheaper going through ebay. You might check them out before taking it to the junk yard. It's not that bad of a job. I am almost finished with mine.
Old Feb 12, 2009 | 11:52 PM
Thumbs up volvo 960 head
thanks,I'm going to check that on ebay.
Old Feb 14, 2009 | 11:28 AM
Hopefully you decide to fix it.
Sorry I didn't reply till now as I have been sick for a week.
Old Feb 15, 2009 | 11:47 PM
Thumbs up thanks
thanks tech and all you guys for all your information
I decided to fix my car I think is going to be Worth it for this type of car
Old Feb 16, 2009 | 06:16 PM
  #17
Glad you decided to fix it.
cdlahoward
Jun 12, 2011 05:03 PM
Carbuff
Dec 28, 2009 06:24 PM
Soloracer
Aug 26, 2006 04:43 PM
ebrobb
Aug 10, 2006 08:25 PM
