Troubleshooting A/C 97 960
So i got my car back from the mechanic i got a rebuild transmission car running awesome now.
Main Issue right now its weather in florida its like being in a oven. My A/c doesnt work stop working: at first the symptoms where this. A/c suddenly on highway stops working turned off and after 30 min or so it start again the compressor and blowing cold other is that when u accelerate the car it stopped blowing from the main vents and i think when u do that it blows on ur feet or the veents for the front windshield.
right now the car is not blowing any type of air i thought it was the blower but then i was feeling that air was coming only from the feet vent at 5 speed and very poorly on the main vents i think is only blowing from the feet, the compressor is engaging i can hear it it stays on the tube bellow the dryer gets cold but the dryer doesnt get cold and i think it have to, I think the dryer is the alluminum tank on the left side of the engine near the strut, am i right?.
so any tips of what should i be looking how should i start any help will be deeply appreciate it.
Chuck101:
To be honest, I am not sure about the vacuum lines/check valve. I am sure it did not hurt to get them squared away.
I ended up replacing the CCU and finding the sensor in the dome light completely occluded with lint. There is a vacuum line that draws cabin air over a thermistor. This information is returned to the CCU, for feedback.
It works now. Regardless, I would pull the dome light assy. out and check the thermistor for lint. I took some photos during the replacement. I have not done much with them as for labeling and annotation. They can be found here.
965 CCu pictures by darkdelta99 - Photobucket
Maybe this will help.
Good luck
Fred
Good luck
Fred
