10^6 ECC post
Old Jul 16, 2011 | 06:06 PM
mrwassman's Avatar
Default 10^6 ECC post
Hello all,
I just put a new Bosch fan motor in my 95 850 along with a new transistor in the power stage (T0-220 form factor) and of course the damn thing wouldn't work.
Before I had a list of codes:
211
411
418
419
And afterwards the parts replacement I only got:
418
So I took the ECC apart and it looked spectacular.
Continuity between the units checked out and so did the voltage spec for the 418 code.
Do I have a 99% chance it is the power stage at this point?
Old Jul 16, 2011 | 07:30 PM
trs80's Avatar
Welcome and that looks high tech! haha
If I remember correctly 418 is for the passenger side cabin temp sensor. Have you checked to make sure its working?
Old Jul 16, 2011 | 08:23 PM
mrwassman's Avatar
418 = No control signal to blower fan power stage
http://www.matthewsvolvosite.com/vol...trouble-codes/
I suppose I should clarify that I am not getting any rotation of the blower motor.
Old Jul 16, 2011 | 10:57 PM
trs80's Avatar
The power stage you reworked may be inop and/or fuse blown. You could try a Junk yard unit to see if it will work without spending a bunch of coin.
Have you crossed post on Matthews site? There are some tech Guru's over there that can better lead you in the right direction. I better clarify that I am no electrical wizard and merely understand the basics when it comes to the ECC system.
Badvibes
Sep 26, 2011 06:15 PM
manyvolvos
Jan 23, 2006 06:10 PM
woodworker
Aug 24, 2005 09:06 PM
dave_n_s
May 17, 2005 11:06 PM
kicmx5
Jan 31, 2005 02:47 PM
