1994 850 compression issue
Old May 19, 2007 | 01:31 PM
Super20's Avatar
Default 1994 850 compression issue
I have a 1994 850 (non turbo). My first issue that I had to fix was the oil cap filler that I replaced. So we'll see if that's the problem. But the next problem that may be aiding in the loss of oil out of the oil cap area is this. The compression coming out of one valve is so strong, it's like an air compressor hissing when i open the cap. That seems like it's a little too much compression for one valve .
Old May 19, 2007 | 01:58 PM
axelm's Avatar
Default RE: 1994 850 compression issue
Turn the engine on, pop the hood and take out the oil dipstick. Do fumes come out from the dipstick tube when you accelerate? If it does then you probably have to service the PCV system. Cost is 150 USD DYI, I don't know how much it is at a shop.
Old May 20, 2007 | 12:09 AM
JPN's Avatar
JPN
Also have the cylinders checked out with a compression gage, if you suspect compression problem.
JPN
rspi
Oct 22, 2013 09:26 PM
And1one
May 29, 2012 10:53 AM
sdguy
Jan 21, 2011 02:59 PM
rspi
Dec 26, 2010 06:06 PM
boxpin
Aug 21, 2009 03:18 PM
