1994 Volvo 850 Misfire
Old Aug 1, 2008 | 05:33 PM
Bowhunter18's Avatar
Default 1994 Volvo 850 Misfire
My car started to misfire about a week ago only when the car has been sitting around for an hour after being driven or it will take a long time to start or both. When it misfires you can smell raw gas in the exhaust and will only misfire for about 4 min at the most. I have changed the cam postion sensor and the fuel injection relay yeaterday. I have done a complete tune up except the coil. Tell me if you guys have had similar problems and what you did to fix them. Please need feedback
Old Aug 1, 2008 | 06:17 PM
Default RE: 1994 Volvo 850 Misfire
Any codes in the ECM?
Old Aug 1, 2008 | 06:30 PM
No codes at all doesn't even pop a check engine light still checked though
Old Aug 1, 2008 | 06:34 PM
Sounds like one of the injectors are leaking when the car is off.
Old Aug 1, 2008 | 06:56 PM
How could one of the injectors be leaking when the car is off? I don't really get that I am thinking that the coil is going bad.
Old Aug 1, 2008 | 08:22 PM
The injectors are like a valve that opens and closes. Sometimes they go bad and bleed down. You can remove the fuel rail and watch and see if they leak.
Old Aug 3, 2008 | 09:11 PM
bitter356's Avatar
I would pull the plugs and inspect. When was the last time the wires were replaced? Cap and rotor?
Old Aug 4, 2008 | 08:32 AM
Psaboic's Avatar
I had a car once that had a weak return spring in one of the injectors and it did the same thing.I would do as Tech suggested, pull the fuel rail and see if one of the injectors is leaking down.
1996Volvo850
Apr 20, 2009 02:50 PM
cmercon
Jan 19, 2009 09:00 PM
cadidj
Apr 21, 2007 02:20 PM
