1995 850 Turbo interchange
Old Apr 1, 2012 | 08:48 AM
acpartsguys's Avatar
Default 1995 850 Turbo interchange
Hi guys!
I need your help with interchange .
I have a 95 850 Turbo that has P/N 5003910 turbo that needs to be replaced.
I found one that is a 9146785 from a 97 T5 turbo wagon.
Can anyone tell me if it will fit or if I need to modify it to fit?
Thanks for your help.
Old Apr 1, 2012 | 10:11 AM
gilber33's Avatar
direct swap. Exact same turbo.
Old Apr 1, 2012 | 11:33 AM
This is awesome!
So I should not worry about the part numbers being different. Correct?
Thank you!
Old Apr 1, 2012 | 12:06 PM
gilber33's Avatar
Its the exact same turbo. 15G. Should be the same part number. You may need to swap exhaust housings, though.
Old Apr 1, 2012 | 12:29 PM
OK. If that is all I have to worry about then I will be just fine. Thank you!
PAVolvo850
Jul 15, 2012 05:40 AM
tork
Feb 12, 2011 11:21 PM
zak66
Nov 19, 2010 08:50 PM
markgrne
Mar 1, 2008 10:22 PM
