1995 850 Turbo Wagon Oil Cooler Line popping off
Old Aug 3, 2006 | 12:39 AM
maddycom's Avatar
Default 1995 850 Turbo Wagon Oil Cooler Line popping off
I have good one here, my oil cooler inlet line is popping off and oil is
shooting out. I reconnect and you can hear when it happens after 30 seconds.
Connection appears secure. I changed oil and filter, oil is making it through
the oil cooler okay. What could be wrong after it leaves oil cooler?
thanks, Greg
Old Aug 3, 2006 | 12:45 AM
Default RE: 1995 850 Turbo Wagon Oil Cooler Line popping off
Are you talking about the cooler on the engine or the Radiator?
Old Aug 3, 2006 | 12:50 AM
maddycom's Avatar
At Radiator. Greg
Old Aug 3, 2006 | 11:08 PM
Are the Metal clips stretched?
If so try putting a wire Tie around the clip to hold it tight.
Old Aug 12, 2006 | 03:29 PM
Luther White's Avatar
I believe the part #'s are: clamp is #6842411 for the oring is #6842413, look here or call them if unsure. http://fcpgroton.com/volvo850cooling.htm
Good Luck
rspi
Sep 24, 2014 08:45 PM
gilber33
Jun 23, 2011 06:23 PM
ahilfman
Aug 19, 2010 10:31 PM
CTE
May 11, 2008 08:21 AM
JPN
Nov 21, 2006 11:00 PM
