1995 Volvo 850 Turbo, pulls to the left when braking...
#21
OK, went to the jy Thursday and got there to late, closing the gates. I asked if they had 850's and the guy pointed at a red 850 wagon. Said it was nice, has a blown engine, said to come back tomorrow, Friday. Went back Friday and the red wagon is a R, not ready for pickin' yet.
So I check out the other 850's and there is a '94 with the aluminum arms on it. The struts are gone but the arms are still there. So I check out the pass side and the arm is there but the ball joint is missing. So I say, what the heck, I can get a ball joint from the stealer for $75 (or from somewhere else cheaper). Still it would be less than the $155+ oem arm and way less than the $190 they quoeted me on the new aluminum '94 arms with ball joints. So I remove the pass side arm, bushings are in real good shape. Take the left one off and notice that the bolts that hold the ball joint to the arm are missing. So I get that off, go back to the pass side and found 2 bolts lying on the ground. I bag everything and decide to clean my hands off in a nearby camary. While whipping my hands off, for some reason I just keep wiping and wiping and wiping and wiping, just can't seem to stop. Finally I look in the back seat at the strut tower there and low and behold, the ball joint that I'm missing is bolted on the bottom of if. LOL
So I snag it and off I go.
I bet someone didn't have the 18 mm socket to get the arms off and decided to hide that ball joint for a Saturday return. Well, I bet they wont do that again. Now I have a set of the aluminum arms with the replaceable ball joints. The bushings and joints are in good shape. One ball joint is a little worn but doesn't flap around. The other one was real tight so I installed it on my car, '95 T-5R wagon.
SCORE!!!
![Smile](https://volvoforums.com/forum/images/smilies/smile.gif)
#23
#24
#26
$35 for the pair. I also just got a new kit from a guy on CL for $50. The kit had 2 new arms and 2 new sway bar end links.
As for the aluminum arms, the problem is finding them. Most people have opp'ed for the cheap after market arms and tossed the aluminum ones. You pretty much have to find someone that has their old Volvo serviced at the dealer to find them. Not sure if mine are OEM, they do NOT say Volvo on them. However, the dealer does sell them, $189 each side (loaded). I guess they still carry them for people that bend them. I seen them on eBay but no where else.
#28
#31
How in the world did you get them so clean?
Also, would it be best to get the nuts from the stealer? I am missing the bolts from the other arm ball joint.
On another note, I noticed that the directions in the manual said to measure the bushings in the arm and have the new bushings pressed in at the same position. I assume this will eliminate the need for or minimize the need for an alignment.
#32
#33
#34
#36
#39
I am not 100% positive but #10 AND #11 seem like them. You might want to call to double check.
Volvo 850, S70, V70 ( - 2000) Urethane Bushings -- PowerflexUSA Online Store
sgreenfield
08-17-2012 08:45 AM
