1995 Volvo 850 won't start
Old Jan 18, 2009 | 01:35 PM
bchesley's Avatar
Default 1995 Volvo 850 won't start
95 850 will not start. The ignition system seems to be OK as I have spark at the plugs. However, when I try to pull the codes from the diagnostic unit A by inserting the test lead into socket 6 there are not codes. The book I have says there should be a 111 code of all is well. When I try to get the fuel system codes using A2 I get 232 which is 'Long term fuel mixture too weak at idle. Any suggestions other that tow it to a Volvo dealer?
Old Jan 18, 2009 | 09:33 PM
JPN's Avatar
JPN
Default RE: 1995 Volvo 850 won't start
If you have spark, most likely it could be:
- Retiring fuel pump.
- Retiring fuel pump relay.
- Retiring ECT sensor.
- Retiring MAF sensor (this one is more noted for poor idling).
- etc...
See attached as well & wait for others replies.
JPN
[IMG]local://upfiles/6892/2420B8E14FB74F17BC0E305FCC4EB777.jpg[/IMG]
[IMG]local://upfiles/6892/348020F435F84DF4A83B3FA17E49BDA8.jpg[/IMG]
Old Jan 19, 2009 | 08:10 AM
Psaboic's Avatar
Most (if not all) 95's have an OBDII port in the center console. If you have a code reader you could plug it in an try to retrieve codes from there as well. I do both on ours just to be sure I get them all when they pop up
jpm2346
Dec 23, 2016 02:35 PM
Rural Juror
Nov 16, 2013 08:35 PM
volvoQ's
Apr 23, 2011 10:35 PM
Zoidbergsvolvo
Nov 1, 2010 09:51 PM
melmel7103
Mar 30, 2008 10:36 PM
