small leak under the coolant reservoir
Old Jan 18, 2009 | 11:55 AM
manuel's Avatar
Default small leak under the coolant reservoir
greetings! i noticed i have a leak from the hose to the coolant resevoir and it look like it leaks only when there is a pressure already. i checked the clamp that holds the hose to the reservoir and look good and tight enough i noticed it leak only between the hose and reservoir.Ill try to check it if there is crack from the lip of the reservoir or maybe because of the hose since the rubber hose are still the original? maybe its already briitle? any encounter? thanks a lot guys.
Old Jan 18, 2009 | 01:39 PM
Default RE: small leak under the coolant reservoir
The bottles tend to crack as well.
Old Jan 18, 2009 | 09:36 PM
JPN's Avatar
JPN
+1 to Tech. I had to replace mine once. I would buy one from FCP Groton. If the hose is original, I would replace all cooling system rubber hoses but this is just me.
JPN
Old Jan 19, 2009 | 08:12 AM
Psaboic's Avatar
I agree. Also, don't try to repair the bottle if it is cracked. I have seen a couple folks try that and it never holds up.
Ejevans34
Jan 5, 2014 08:54 PM
JPN
Dec 29, 2013 10:57 AM
beejay
1998-2000 model year V70
Jun 29, 2012 07:53 PM
docmot
Jun 3, 2010 06:51 AM
8T9GTA
Nov 19, 2006 12:22 PM
