1996 volvo 850 turbo wagon vacuum hose location
I just did a complete head overhual, and finally got the head back on. i replaced my pcv system, and timing belt ETC, now i am doing all of my vacuum hoses, and i have no idea where most of them go; but i may be able to piece them together. But i cant figure out what hose connects to the passenger side of my intake manifold. Is it the fuel pressure regulator ? or some kind PCV vent ? i have no clue. I also am getting some silicone vacuum hoses, which run about $3.40 per foot, and i have to buy the whole 15 foot package...that's $50 bucks in vacuum hose... + the 5 foot of the larger size i need.... Do i need silicone vacuum hose? i heard if i use normal vacuum hose, it will get too flexible when hot and suck closed under vacuum due to the high temperatures created by the turbo. is this true ? any other information or tips to make my life easier would be greatly appreciated, Thanks.
there should be a Vac diagram under your hood..
You might want to give these a look see.
http://www.matthewsvolvosite.com/for...hp?f=1&t=28472
http://www.matthewsvolvosite.com/for...hp?f=1&t=44224
Thank you, that is what i needed to know. its been a while since i took these parts off, since i had a lot of work to do to my head. its been about a month. I only have time to work on it on the weekends.
