1997 850 won't start
Old Feb 28, 2013 | 08:39 AM
jdsmith's Avatar
Default 1997 850 won't start
When I turn the key, I hear a "whirring" sound but the starter doesn't engage. Should I replace the starter or look elsewhere first? The battery is new.
Old Feb 28, 2013 | 09:22 AM
That would be my guess.
Old Feb 28, 2013 | 11:10 AM
boxpin's Avatar
Sounds like the starter solenoid is firing, the armature is turning but the shift lever is not moving. It may be able to be repaired but best to replace it.
Old Feb 28, 2013 | 11:52 AM
treborly's Avatar
Question
Have you tried rotating your tires?
Old Feb 28, 2013 | 12:31 PM
The starter drive could also have failed. It's function is to lock up in one direction so it turns the flywheel and then once started allows the flywheel to spin the starter drive while disconnecting from the starter drive shaft itself.
In Boxpin's diagram it's the over-running clutch.
But in either case, replacing the starter should cure your problem if we're understanding your noise correctly.
Old Mar 2, 2013 | 12:28 AM
gdog's Avatar
Take the starter off; look at the flywheel teeth. If they're all ground off and knarled, you need a flywheel. If the flywheel teeth look OK, renew (replace w/new or rebuilt) the starter.
ashort
Jun 11, 2015 09:40 AM
jt807
Mar 21, 2013 06:35 AM
blackstonehere
Jan 28, 2013 08:21 PM
Erica Alpuerto
Apr 3, 2012 11:50 AM
salty10is
Jun 6, 2008 08:52 AM
