1997 850glt no start problems after sitting for 2 years
Old Dec 28, 2013 | 03:35 PM
inkydink's Avatar
Default 1997 850glt no start problems after sitting for 2 years
I have read through the post and found good advice. My problem is that after replacing the ignition switch, fuel pump, fuel relay and putting in a new battery this car will not start. I have pulled a spark plug and have no spark. Warning lights do not come on and the fuel pump does not engage. Everything else appears to turn on lights, ac blower, windows etc.. Before car was parked it ran ok. After reading a few post i believe it may be the ECU but not sure. the only code showing up is P0410 (secondary air injection system). Need some advice.
Old Dec 29, 2013 | 12:15 AM
gdog's Avatar
If you have no spark then why did you replace the parts you did?
I would ck out the cam sensor and engine speed sensor (on the crank flywheel) first for no spark. Oh yeah, make sure the immobilzer is not set!
And pretty sure if the ECU doesn't see spark (tach) signal, it won't engage (turn on) the fuel pump relay. So you need to fix that problem first.
Old Dec 29, 2013 | 12:25 AM
The P0410 is an emissions code and shouldn't have any impact on the vehicles ability to start.
Any chance while trying to start it you jumped it and momentarily had the cables reversed ??
Have you physically tested all the fuses for continuity ??
Since it sat for two years I'd do a really good visual inspection and see if you find any wires chewed on by critters. Especially the cam or crank sensor leads.
Did you check for spark at the coil too or only at the plug ??
Old Dec 31, 2013 | 02:09 PM
inkydink's Avatar
Problem was fixed. Middle j fuse needed to be replaced. Thanks to all for all the help.
kenbiello
Mar 24, 2014 08:17 PM
Ed_F
Apr 18, 2011 10:58 AM
solitarypasserby
Dec 11, 2009 11:24 AM
ttgxc
Jun 22, 2009 11:01 AM
copycat923
Jan 27, 2006 01:55 AM
