4 speed blower switch - 850 Wagon
Old Aug 30, 2005 | 04:33 PM
golfrepairmanri's Avatar
Default 4 speed blower switch - 850 Wagon
The 4 speed blower switch on my 95 850 wagon only works in the 4th position. It the switch shot, or is there a relay I should look for? All help would be appreciated.
Thanks
Old Aug 30, 2005 | 09:56 PM
Default RE: 4 speed blower switch - 850 Wagon
On the climate box behind the glovebox insert is a blower resistor That controls fan speed 1-2-3. Fan speed 4 is direct voltage.
Old Oct 27, 2008 | 08:30 PM
stecz's Avatar
Every since I bought my '93 850, the 4th speed on the fan hasn't worked, but 1-3 worked fine...
recently 1-3 just quit on me... So, I've pulled the resistor and I'll try and get a new one in the next couple of days....
But, the question is, since the 4th speed is just straight 12 volts, what typically makes it not work. When I turn the fan the the 4th setting, I get the noise of the recirculation flap (I think that's what that is), changing positions, but the fan doesn't come on.
I haven't had a squeaky fan either (when it was working), so I don't think that is the problem... Anywhere else to look?
Thanks
John S
Old Oct 28, 2008 | 08:22 AM
Ozark Lee's Avatar
Start by checking fuse number 5. If the fuse is good chances are the relay is bad.The relay is on a small shelfnext to the blower resistor. There are actually 2 relays on the shelf. One is the A/C compressor relay and the other is the max fan relay. You can see the wires at the base of the relay and the max fan relay has the wire colors Green, Red, White, Green/Red, and Black.
...Lee
Old Oct 28, 2008 | 06:57 PM
stecz's Avatar
ok thanks... I've checked the fuse and it's good. I'll take a look at the relay...
Old Oct 28, 2008 | 09:30 PM
stecz's Avatar
update:
Replaced the resistor (good bye $90), that fixed speeds 1-3.
Replaced the relay - good buy $10 and hello fourth fan speed.
The relay to look at is the one on the left. You just need to remove the interior of the glove box to get to it. The interesting thing is that the resistor has two actuators, so the relay was clicking when I turned the fan switch to the fourth setting. But I got a replacement from Advance Auto parts and it fixed the problem.
John S.
wkankovsky
Jun 27, 2014 02:59 PM
mathieu_p
Jan 19, 2013 02:06 PM
itr
Nov 22, 2010 07:05 PM
sdc2000
Jun 29, 2009 04:52 AM
parrym
Nov 7, 2004 11:30 AM
