850 brake fluid resevoir switch leakage
Old May 26, 2009 | 08:01 PM
cheewooi's Avatar
Exclamation 850 brake fluid resevoir switch leakage
Hi,
I found that leakage of brake fluid reservoir switch. Can the switch be replaced by our self without need to reset the ECU or whatever programming?
Here's some photo of the leakage:
Some closeup view
Old May 26, 2009 | 08:08 PM
That is the EBD switch you can replace it but you will have to bleed the brakes afterwords.
Old May 26, 2009 | 08:36 PM
850tony's Avatar
nothing on the ECU needs to be reset.
Old Jan 20, 2012 | 12:32 PM
npharper's Avatar
Default Same Problem
I have a brake fluid leak at the same location on my 1996 850 non-turbo. It looks like an easy fix, but I can't find any EBD valves/switches online. Do you know a vendor who sells them?
Thanks.
J Dubb
Feb 5, 2013 04:20 PM
RestrictedAccess
Jul 13, 2010 12:53 PM
RedTurbo850
Jun 21, 2007 08:47 AM
NoleWithAVolvo
Jan 25, 2007 12:10 AM
mikeys
Aug 23, 2006 10:20 PM
