850 a/c issues
Old Jul 5, 2009 | 04:09 PM
lmjua's Avatar
Default 850 a/c issues
1996 Volvo 850 GLT non-turbo a/c come on and sometimes within ten minute cycles off. I have checked the freon and the system is fully charged. When it's on, it definitely cold. Sometimes it will stay on for hours without cycling off. Turn the car off and it come completely back on as usual.??????????
Old Jul 5, 2009 | 07:36 PM
Sounds like the compressor needs to be reshimmed.
Old Jul 5, 2009 | 10:32 PM
850tony's Avatar
that or a possible messed up ecc?
Old Jul 6, 2009 | 12:17 AM
gdog's Avatar
You know, my car had these exact symptoms when I first purchased it. AC would work perfectly sometimes; other times it would shut off for no reason.
When it happened to me, the light behind the snowflake switch would go out (does yours do this?). Turned out to be bad (high resistance) switch itself (snowflake switch in dash).
I would make sure that's it before you buy a new one; seem to remember it was quite expensive from the dealer. I ended up taking it apart, cleaning it, and put it back together (very tricky, lots of tiny springs!) but it's been working fine since (several years now).
Boostwhat
Sep 7, 2005 06:25 PM
Micks Volvo
May 26, 2005 02:55 AM
David
Apr 13, 2005 01:42 AM
tassadar30
Dec 2, 2003 02:42 AM
