86 Volvo740T randomly dies
Old Jan 29, 2007 | 01:23 AM
Sean in Austin's Avatar
Default 86 Volvo740T randomly dies
My 740 Turbo (I really really like this car) dies with no warning. In town, on the highway, cold, hot, rainy, dry...does not matter. It goes fine and then just starts decellerating until it stops dead. All lights and power is on. I let it sit for a bit and it starts right up and runs fine. Sometimes it runs fine for weeks with no problem and sometimes it will happen four times in a day. Totally random. I read through many of the posts and have not found this exactly. Any help would be so very appreciated. Thankyou in advance, Sean
Old Jan 29, 2007 | 08:35 PM
Default RE: 86 Volvo740T randomly dies
Check fuel pump relay
Check fuel pump
Check the power stage
Check the speed sensor
Old Jan 31, 2007 | 01:27 AM
Thankyou very much. My one question is on the power stage. As in see if the fuel pump is getting power? thankyou again.
Sean
Old Jan 31, 2007 | 08:39 PM
The power stage controls ignition.
You can check and see if you have power to the pump.
But the power stage doesn't control the pump.
Old Feb 20, 2007 | 11:14 PM
volvoyoungster's Avatar
my 87 760 t. is doing that too. i replaced the fuel pump relay and it seemed to work for a bit
then the intank fuel pump went and i replaced that. and the next day my turbo went....
so i scrapped the car!!!
good luck
but check the relay for a crack in a solder!
if you know how just resolder them!
its the big white relay on the left side of the panel i think? or it is in mine! and the relays are in under the radio.
vwNIK
jayson44
Apr 11, 2013 01:52 PM
pdunn
Jan 24, 2012 07:56 AM
oct6454
Dec 25, 2011 08:15 PM
dieselsnowmobile
Nov 7, 2011 07:32 AM
jamie
Jul 1, 2008 10:34 AM
