850 GLT Sedan-1997, Brake Light Switch
Old Feb 10, 2014 | 12:49 PM
romeojim22's Avatar
Default 850 GLT Sedan-1997, Brake Light Switch
Can anyone tell me how long it will take to put in a Stop Light Switch?(Brakes Lights not working). Any helpful hints in installation?
Old Feb 10, 2014 | 01:16 PM
About 5 minutes. Try not to break the fragile plastic clips.
Are you sure the switch is bad?
Old Feb 10, 2014 | 01:47 PM
romeojim22's Avatar
Default 850 Switch...
Bulbs...fuse ok...all other lights work other than brake lights...all went out at same time...any suggestions?
Old Feb 10, 2014 | 01:58 PM
Ignition switch or head light switch.
How do you know that the bulbs are good?
Old Feb 10, 2014 | 02:11 PM
romeojim22's Avatar
Default 850 Switch
Tested bulbs and they light up in other slots...Just going by the suggestions of many other Volvo owners...it will cost me 30 bucks to find out..but very open to other suggestions
Old Feb 10, 2014 | 06:20 PM
I linked a couple of video's on the other thread you posted on. Ignition switch as well as the head light switch can cause brake light issues. This I know.
You should get an ohm meter and check for power at the switch before replacing it.
Old Feb 10, 2014 | 07:18 PM
romeojim22's Avatar
Default 850 Switch
Thank you for your assistance... I will check out the videos and let you know...
Old Feb 10, 2014 | 10:15 PM
Brick850's Avatar
Robert can you explain to me how a head light switch affects brake lights?
I would expect them to affect tail lights but not brake lights.
I am confused.
I would have thought either the brake light switch, or the bulb failure warning relay might be the issue.
Old Feb 19, 2014 | 11:42 AM
romeojim22's Avatar
Default Brake light switch upper clip
I can't see the other clip on the Brake light switch...how do you get at it without braking it?
itisraffi
Mar 30, 2014 09:06 PM
Scott Harn
Dec 9, 2013 04:25 PM
matt01
May 15, 2011 07:58 AM
Turbo Theaters
Sep 1, 2010 08:33 AM
dwbf1
Aug 20, 2010 12:39 PM
