850 interchangable parts question
Old Aug 5, 2014 | 07:10 AM
Kw850turbo's Avatar
Default 850 interchangable parts question
newbie here... i have a 96 850 turbo wagon, recently i have found a 94 850 turbo wagon at a junkyard, same engine, will the starter, oil pump, water pump, alternator, ac compressor, or any of the engine parts interchange with mine? if it makes any difference, it has same obd 2 port as mine in front of shifter, also will tranny or front end rear end suspension parts work on mine? thanks kw
Old Aug 5, 2014 | 09:29 PM
firebirdparts's Avatar
Totally interchangeable as far as I have seen.
There are some minor differences in certain things on the car, like some of the wiring and emissions stuff is ever so slightly different. The ABS looks slightly rearranged, you can see that. But on engine parts I haven't found any differences at all.
Old Aug 6, 2014 | 07:16 AM
Kw850turbo's Avatar
Default thanks
thank you fb parts, rear end sits low, noticed shock boots were corroded, and bump stops for springs coming off. should i start with springs first? cant afford to do both at same time, if so do you reccomend any?
billlutz
Jul 23, 2014 11:07 AM
skhalsa86
Apr 12, 2012 03:25 PM
otowwa
Jan 7, 2011 08:57 AM
myanny
Aug 13, 2009 01:53 PM
Volvo850GLT
Dec 27, 2007 10:33 PM
