850 Lower control arm Procedure
Old Jun 18, 2007 | 09:58 AM
etype38's Avatar
Default 850 Lower control arm Procedure
Hi,
Has anyone got a procedure for replacing the lower control arms on a 95 850?
Thanks,
Paul G
Old Jul 6, 2007 | 06:38 PM
JPN's Avatar
JPN
Default RE: 850 Lower control arm Procedure
Hi Paul,
Here's a procedure:
1. Jack up the front and put it on jackstands. Ensure that the car is solidly rested on jackstands by shaking it. It should feel solid.
2. Remove wheel.
3. Remove ball joint clamp bolt & nut (this was the hardest part for me, I had to use PB Blaster, a propane torch, a chisel & hammer).
4. Separate ball joint from the knuckle.
5. Remove 2 bolts & nuts at the control arm to subframe attachment. This shouldn't be difficult.
6. Done. If you can't take the control arm off the subframe with all fasteners removed, use a soft-face hammer and tap on it; this should dislodge the control arm.
7. Replace all lock nuts with new ones.
Good luck & be safe.
EDIT: The 850 uses either aluminum or steel control arm, depending on the model year/VIN. If aluminum, do not apply too much force/impact, as it can permanently damage the control arm. Aluminum control arm should have replaceable ball joints, while steel control arm has integral ball joint, I believe.
JPN
Old Oct 13, 2008 | 07:28 PM
terrencekeenan's Avatar
In a '98 V70 AWD, I would like to know if there is anything modified from the above procedure for an 850. In no. 5, there seem to be 4 bolts attached to subframe per arm and they look to be very difficult to get to.
Thanks,
Old Oct 13, 2008 | 07:50 PM
Everything else is the same. The 4 bolts per side are on the newer cars. Try to use a thin offset wrench and you should be fine.
f8talh8red
May 21, 2009 10:30 AM
sy381
Jul 2, 2008 07:33 AM
theotherpilot
Apr 5, 2008 09:51 AM
tech
Feb 21, 2008 07:52 PM
go2sharks
Feb 25, 2007 12:08 AM
