850 radio codes
Old Dec 29, 2007 | 02:17 AM
dancewithmike's Avatar
Default 850 radio codes
I just bought a Volvo 850, but the radio needs a code. How do I go about this?
What would a shop charge me?
Thanks! =- )
Old Dec 29, 2007 | 04:07 AM
JPN's Avatar
JPN
Default RE: 850 radio codes
Some cars seem to have the code written on the radio itself; it needs to come out of the nest. If this does not apply, visit a local Volvo dealer, give them your VIN and they should be able to get you the code. Note, that some dealers seem to require a photo ID. As to how much they would charge, I am not certain. Other members should be able to give you some ideas.
Good luck,
JPN
Old Dec 29, 2007 | 04:08 AM
axelm's Avatar
Most dealers do not charge for this. You will probably need to show proof of ownership of the car. If the radio is the original factory radio all the dealer needs is the VIN. If the radio has been changed you will need the radio serial number.
Some dealers will give you this info over the phone so you might not even need to go there personally.
Good luck!
Old Dec 29, 2007 | 08:00 AM
jks2's Avatar
Also, check in the owners manual. Sometimes the code is on a credit card sized card.
Old Jan 2, 2008 | 05:01 PM
Quincy56's Avatar
I picked up a replacement radio at the junkyard. Took the radio into the parts dept of a dealership near me, and in a minute or two, I had the code for it, no charge.
John
Old Jan 3, 2008 | 08:50 AM
Psaboic's Avatar
I had to go to the dealership to get the code for mine. No charge, but they made me produce the registration for the car along with a photo ID. It was the same when I wnated a replacement key made
Glenn
gabyman97596
May 14, 2007 09:52 PM
rmmagow
Apr 23, 2006 11:52 AM
cranky
Aug 5, 2005 09:46 PM
