850 stalls when slowing down to a light or in gear except when i disconnect the iac
Old Nov 6, 2019 | 12:48 PM
mescalinedreamz's Avatar
Default 850 stalls when slowing down to a light or in gear except when i disconnect the iac
installed a new idle air control valve hoping to fix it..both old valve and new check out fine. Anyways I can plug the idle air control valve in when the car is cold and it won't let me put it in reverse or drive without stalling..park and neutral I get a steady 1000 Rpms..when warm I can feather the gas and take off but not when cold. When slowing to a light I can stop and a second later the Rpms drop to zero.
Now with the idle air control valve disconnected it'll die from cold at idle in park or neutral until warmed up and then I can drive it normally but gas mileage suffers. So I usually warm it up with the iac plugged in and unplug it when warmed up..or else I keep the iac plugged in and throw it into neutral at every stoplight.
I'm thinking a sensor..maybe the temp sensor located under the thermostat..but not sure..gonna test it when cold and warm tomorrow. It's getting cold here in Ohio and it takes awhile to warm this thing up..thanks!
platinum_ghost
Nov 7, 2012 12:41 PM
Msuperbauer
Aug 31, 2012 10:18 PM
537playing
Dec 29, 2009 02:18 PM
jmarble
Dec 27, 2009 09:36 PM
WagHag
Nov 18, 2007 12:05 AM
