Cold Morning Idle
Old Dec 21, 2009 | 09:20 PM
537playing's Avatar
Default Cold Morning Idle
My car will start quickly in the morning, but will only idle in the 900RPM range at first, then drop to its normal range of 700-750RPM. I find this strange as I would suspect 1100 to a high of 1500RPM. In any case, I shift the car into gear, hit the gas petal, and it stalls. Keep in mind I never allow the car to fully warm up.
Is there a sensor which affect the Fast Idle on this car?
Old Dec 21, 2009 | 09:36 PM
SACS80's Avatar
On certain models, when the car is started, idle speed may be noticeably higher than normal for a short period, depending on the temperature of the engine.
This has been done to help bring components in the emission control system to their normal operating temperature as quickly as possible, which enables them to function normally.
Old Dec 23, 2009 | 09:24 PM
537playing's Avatar
Are my low RPMs the norm? What are your idle RPMs?
Old Dec 25, 2009 | 12:59 AM
SACS80's Avatar
My car is usually around 1000 for cold start-ups. Duration at this RPM depends on the temp. Not long though, usually less than 15-20 sec....Then it goes down to around 500.
Old Dec 25, 2009 | 08:37 PM
537playing's Avatar
With the numbers you've posted, then my stalling is being caused by something. I know that I've replaced one O2 sensor (front bank) and not the other. Do you think that replacing the other O2 could resolve my issue? I hate having to throw money on parts that will not solve/improve the performance.
Old Dec 29, 2009 | 12:30 AM
SACS80's Avatar
You could be on to somthing.
I heard that the O2 sensor is a very common code that is usually always tied to every error code you get on a car. Tech may be able to verify this....
Old Dec 29, 2009 | 02:18 PM
537playing's Avatar
The only problem is that I don't have any codes, just this stalling/hesitation issue. I'm guessing the O2 sensor is failing, but not shot, as the ECU is overcorrecting the fuel mixture.
prophet_of_profit
Jul 29, 2009 09:14 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
volvolove
May 20, 2007 07:07 PM
veso_ht
Apr 30, 2007 02:42 PM
tomskuce
Nov 27, 2006 08:12 PM
