Volvo 850 - Rough idle for 10-30 seconds on cold Start?
Old Aug 29, 2012 | 05:08 PM
Msuperbauer's Avatar
Default Volvo 850 - Rough idle for 10-30 seconds on cold Start?
Thats it, after the 10 - 30 seconds of hard sputtering and coughing, it smoothes out and runs great?! Today I cleaned the idle/Air control valve thing and it seems a little better, but initially started the same way? I did just run seafoam through the gas prior to this issue where else can I look? This is getting annoying, lol..
Old Aug 30, 2012 | 06:22 AM
slimflex2's Avatar
your idle/air control valve could be bad. is there a way you could get one from a junk yard and swap it and see if that helps?
Old Aug 30, 2012 | 07:22 PM
Did you have problems prior to the seafoam?
Old Aug 31, 2012 | 06:28 AM
No problems like this prior to. Cleaning out the iac valve helped, but it's still happening, less rough of an idle than before, but still happening
Old Aug 31, 2012 | 10:18 PM
Cool
update: Looks like new spark plugs solved the problem. Swapped them out today and baddabing! Problem solved. I was thinking today (this is what happened to my lawn mower) hard to start after having old gas, it was running rich and it fouled the plug. So I thought, maybe the seafoam caused my Volvo to run too rich and foul a plug or 2.. Correct I was!
Mononga
Oct 28, 2012 11:36 AM
JTK
Feb 14, 2012 07:10 PM
ibified
Oct 2, 2011 07:04 PM
DadsVolvo
Feb 27, 2011 11:40 PM
