850 starter bolt location question
Old Jun 20, 2010 | 11:50 AM
cedar's Avatar
Default 850 starter bolt location question
Hi,
I am replacing the starter in my 95 850, and I was wondering if anyone has any tips on how to reach the lower bolt that holds the starter to the crankcase. It seems to be hidden behind the clutch slave cylinder and I can't even see it!
Any suggestions? or other tips on this job?
Thanks!
Old Jun 20, 2010 | 06:25 PM
gilber33's Avatar
From underneath?
Old Jun 21, 2010 | 06:56 PM
cedar's Avatar
That may be the best way if I take out the plastic guard under the radiatior. As it is, you can hardly see up there from underneath at all!
Old Jun 21, 2010 | 07:18 PM
ibified's Avatar
yes, you have to get at that bolt from underneath. Pull off the splash shield (and take a second to be amazed that you still have one - they usually fall off) and you should be able to get right on it.
Old Jun 22, 2010 | 12:13 AM
gdog's Avatar
Is starter installation different on manual trans than autos?
I just pulled off the fan shroud and then everything was then accessible...
Old Jun 22, 2010 | 02:11 AM
ibified's Avatar
gdog: it shouldnt be, because the manual trans uses the same starter as the automatic.
Old Jun 22, 2010 | 04:32 PM
cedar's Avatar
Although it makes sense it would be easier to see on an auto, since they don't have a clutch slave cylinder
Thanks for the tips everyone!
dsteele485
Aug 28, 2012 08:11 AM
Counselor828
Aug 22, 2011 12:19 PM
SMTurbo5
Jun 5, 2009 02:57 AM
geminiys
Oct 9, 2007 12:17 PM
JPN
Sep 10, 2006 03:05 AM
