850 T5 GLE Codes
Old Aug 30, 2005 | 12:03 PM
mattyremf's Avatar
Default 850 T5 GLE Codes
Can anyone give me any help????
A1 Description
1-1-4
1-2-4
1-4-3
2-3-2
3-1-3
A2
2-3-1 Heated Oxygen sesnor(lean mixture/part throttle) 94-up
2-3-3 Idle valve-closing signal
3-1-4 Camshaft position signal missing or defective
4-1-4 Turbo boost regulation
A3
1-4-2
2-1-1
2-1-2
4-4-2
4-4-4
A7
1-2-2
1-3-2
B1
1-2-1
1-2-2
1-2-3
1-2-4
1-2-5
1-2-6
1-3-1
1-3-2
1-3-3
1-3-4
1-4-5
1-5-2
2-1-2
2-2-2
2-3-2
2-3-4
2-3-6
3-1-1
3-1-4
3-2-1
3-2-2
3-2-4
4-1-2
4-1-3
4-1-4
4-1-6
4-1-8
4-1-9
4-2-10
B2
1-2-2
B5
2-2-2
Old Aug 30, 2005 | 09:42 PM
info2x's Avatar
Default RE: 850 T5 GLE Codes
A1 Description - Trans
1-1-4 Program selector open circuit or short circuit to supply
1-2-4 Mode selector faulty or short circuit or control module fault
1-4-3 Kickdown switch faulty or short to ground
2-3-2 Speedometer signal missing
3-1-3 Faulty signal from gear position sensor (PNP)
A2 - Engine
A3 - ABS
1-4-2 Faulty brake pedal switch, open or short
2-1-1 Left front wheel sensor, not signal on moving off
2-1-2 Right front wheel sensor, no signal on moving off
4-4-2 Pump pressure low
4-4-4 No power supply to valves in hydraulic unit
I'll need to dig for the otherones, but that should give you plenty to start on.
Did you clear the codes and these came up again or were these all there from the first time you checked?
For future referance http://www.volvospeed.com/volvo_performance.php
See if these help.
[IMG]local://upfiles/853/0D2AD78FC9C34349B9FBC7ECE7799E10.jpg[/IMG]
[IMG]local://upfiles/853/48BC332E64EF42FD82E2CA4960A07E43.jpg[/IMG]
[IMG]local://upfiles/853/98F4FD7F5FF545128A9622D6CA43EFAB.jpg[/IMG]
[IMG]local://upfiles/853/AD00A8896A1146A89C6D079022706E51.jpg[/IMG]
[IMG]local://upfiles/853/B1AAFF9BD6694A45B3FE5280F0A14F5E.jpg[/IMG]
Old Aug 30, 2005 | 09:43 PM
2 more
[IMG]local://upfiles/853/4C999A92FBE0400B9A8167CC5A3736A2.jpg[/IMG]
[IMG]local://upfiles/853/780EE5B0F491478B9DD481D021656260.jpg[/IMG]
Old Aug 30, 2005 | 09:44 PM
info2x's Avatar
guess I don't need to get my books out now [sm=boohoo.gif]
Old Aug 30, 2005 | 09:47 PM
SORRY [sm=bangbang.gif]
BGoins12
Apr 29, 2011 09:23 AM
gabyman97596
May 14, 2007 09:52 PM
dodgedemon
Mar 27, 2007 10:14 PM
cranky
Aug 5, 2005 09:46 PM
