850 Trans Fluid Refill Amount?
Greetings, I'm replacing my radiator in my 1996 850 Turbo Wagon and I figure I will drain the transmission from the 24 mm bolt while I'm down there anyway and the Trans fluid system is already open. Since I'm draining at the Trans and replacing the radiator at the same time will that drain all 8 qts ? I'm wondering how much new fluid to put in before test driving and checking. I did not accurately capture all the lost fluid to measure. Thanks for any advice.
daver
07-27-2013 06:04 PM
