850 turbo. abs, srs,traction control lights on after rebuild
Old Jan 25, 2010 | 02:55 PM
pj91gsx's Avatar
Default 850 turbo. abs, srs,traction control lights on after rebuild
i rebuilt the engine, replaced the transmission and changed the gear in the gauge cluster to read mileage on the OD again. im not sure why my abs, srs and traction control lights are on, otherwise the car runs great. This car is an automatic if that helps
Old Jan 25, 2010 | 08:07 PM
fcpgroton's Avatar
Former Sponsor
What year is it? If it is a 94 - 95, you can check to see what codes are in the computer. If not then you would need to get a scanner to check for codes.
In the mean time, I would disconnect the battery to see if it resets the ABS computer. More then likely the ABS controller is fault and needs a rebuild.
OnATrail
Jul 18, 2017 11:04 AM
Mr Softee
Jul 26, 2012 11:24 AM
PerthX
Apr 25, 2010 09:53 PM
raducu76
Jul 26, 2008 09:46 AM
RadiatorSprings
Apr 25, 2008 05:26 AM
