850 turbo overheating
Old Jun 28, 2011 | 03:46 PM
minn4ever303's Avatar
Default 850 turbo overheating
My wife drives a 1995 850 turbo. The radiator had a small hole in it, I replaced the radiator and thermostat. now the engine keeps overheating, Does anyone believe that it could just be the cap that is malfunctioning or do you think that it is most likely the water pump? I am leaning toward the water pump. After replacement of radiator there are no external or internal leaks.
Old Jun 28, 2011 | 04:28 PM
MattyXXL's Avatar
It could just be an air pocket.
Old Jun 28, 2011 | 04:33 PM
I did the bleed process as I was told. After installing the radiator I let it idle for twenty minutes with the cap off. Is there something else that I should try to get air out of the system?
Old Jun 28, 2011 | 05:10 PM
MattyXXL's Avatar
Have you squeezed the hoses with the cap off when its warm, Kind of like pumping them?
You can also crack open the block drain for a couple seconds and refill..
Old Jun 28, 2011 | 05:53 PM
MattyXXL's Avatar
You can also try jacking up the passenger side with the car running and warm then lowering it down then repeating.
That might help get the bubbles moving.
Old Jun 28, 2011 | 08:27 PM
Thanks for the tips, I will continue to troubleshoot.I'll let you know if I have any success.
Old Jun 29, 2011 | 12:49 AM
trs80's Avatar
The cooling fan kicks on?
Old Jun 29, 2011 | 07:25 AM
Remove the t-stat and see if it still tries to overheat. Maybe it's bad.
Old Jun 29, 2011 | 09:41 AM
fan kicks on no problem. If i just leave it sitting and idle and throttle up it doesn't overheat. As soon as I drive it for a couple of miles after warming up for about 20 minutes is when she rises in temp.
Old Jun 29, 2011 | 01:02 PM
MattyXXL's Avatar
Could be a bad temp sensor...
Old Jun 29, 2011 | 10:36 PM
Henry10's Avatar
You can test the ECT (Engine Coolant Sensor) by measuring its resistance at certain temperature. Run a search here in this forum for the specs.
Mikelos
Mar 8, 2012 07:56 PM
DNJ
May 28, 2009 11:53 PM
meghuzzah
Jul 28, 2008 01:27 PM
tshort01
Jul 2, 2008 10:09 AM
asanders
Sep 10, 2007 11:58 PM
