850 Turbo Oxygen Sensors
Old Sep 21, 2007 | 02:54 PM
elchingon2002's Avatar
Default 850 Turbo Oxygen Sensors
Does anyone have the Bosch part numbers for the generic Bosch 4 wire Oxygen sensors for a 1995 850 Turbo (both front and rear O2 sensors)?
I received a check engine light and fault code 2-3-2 "long term fuel mixture too lean or rich at idle". At first I thought the problem was caused by a defective mass airflow sensor, but I changed it and I still get the same fault code.
So my next best guess is Oxygen sensors. I have the original O2 sensors in the car with 148K miles on the car. I believe most people say they usually only last 100K miles.
I have read that I should change both O2 sensors at the same time, so I plan on doing that. In an attempt to save some money, I want to use the generic Bosch 4 wire O2 sensors instead of the 'direct plug in' OEM parts. But I have no idea how to figure out which specific Bosch parts to purchase.
Any suggestions?
Thanks!
Old Sep 21, 2007 | 06:53 PM
Default RE: 850 Turbo Oxygen Sensors
Make sure you have no vaccum leaks before just replacing the sensors.
Old Sep 22, 2007 | 05:21 AM
axelm's Avatar
You can get a new set of vacuum hoses for about 50 bucks + S&H at StylinMotors. Maybe you should try that before changing the sensors.
Old Sep 22, 2007 | 10:53 AM
JPN's Avatar
JPN
And I personally would go with direct fit OEM rather than universal type. I remotely remember someone's having a bad luck with the universal device.
JPN
Old Sep 22, 2007 | 04:07 PM
I did my PCV system a few weeks ago and replaced a few of the vacuum elbows that were showing some age. I'll double check everything to make sure nothing has become disconnected.
I'll probably do the vacuum hoses first.... then the direct fit OEM O2 sensors if needed.
I'll report back in a week or two after I complete the maintenance.
Thanks for all the suggestions! You guys are very helpful...
Old Sep 22, 2007 | 08:49 PM
jmana's Avatar
I don't understand why the OEM ones are so expensive compared to the universal ones. Are there any places to buy the OEMs that don't cost hundreds of $$$$$?
Old Sep 22, 2007 | 09:12 PM
JPN's Avatar
JPN
I too, don't know why they are so expensive; they are nothing but zirconium tip with some electrical wires.
If http://www.fcpgroton.com/volvo850oxygensensors.htmsounds too high, may be eBay could do?
JPN
Old Sep 25, 2007 | 02:07 PM
phoenix_iii's Avatar
www.rockauto.com
I also have a 5% valid coupon. Will have direct replacement OEM as well as have the correct universal.
Old Sep 25, 2007 | 02:49 PM
Thanks for the link! The cost for the direct fit Bosch is not much higher than the universal. I'll go for the direct fit... A 5% off coupon would save me around $12 which would be great! Is it an online coupon?
Thanks!
Old Sep 26, 2007 | 07:30 AM
761136646814
Here's how to use it:
* Enter your code in the "How did you hear about us" line of the shopping cart.
* If you are using our traditional HTML catalog, please click the "Set" button to the right of the field.
* Your discount will automatically appear, subtracted from your order total.
**NOTE: We sometimes get calls from people who put the word "discount" in front of their code and do not get the discount. Please enter ONLY the discount code, no other words or numbers.**
Rockauto is usually quite competitive with parts, has some rare parts for cars, and I have sent cores back to them and received even MORE then what they stated the core refund was worth. =)
Vee70
Oct 15, 2010 02:57 AM
Tmelysh
Jan 29, 2010 11:24 AM
denver005
Nov 3, 2009 11:22 PM
schmidtsr
Oct 26, 2007 07:16 PM
mhcastellow
Apr 19, 2006 09:00 PM
