making my 94 850 turbo faster
Old May 14, 2010 | 05:52 PM
fattyearlman's Avatar
Default making my 94 850 turbo faster
is there anyway i can make my car faster by spending little to no money?
Old May 14, 2010 | 06:51 PM
Legendsecko87's Avatar
Yup. Trade it for a faster car.
Cheap, Effective, The Best
Choose one.
Old May 14, 2010 | 08:39 PM
gilber33's Avatar
I'm guessing that if you don't know about the obvious ways to add a couple horsepower, your car needs a stage 0 first.
Old May 15, 2010 | 12:26 AM
boxpin's Avatar
Adjusting your wastegate actuator rod will get you a bit. Installing a Manual boost control will get you quite a bit.
Old May 15, 2010 | 11:03 AM
how do i do that?
Old May 15, 2010 | 03:00 PM
gilber33's Avatar
how do i do that?
don't do that unless you have a boost gauge. have you done a stage zero? A 'little to no money to make my car faster mod' can turn into 'quite a bit to a lot of money to fix my broken car mod' pretty quick.
Old May 15, 2010 | 09:16 PM
how exactly do i do a stage zero?
Old May 15, 2010 | 09:32 PM
gilber33's Avatar
cap, rotor, plugs, hoses/vac lines, PCV, and fluids. That's your basic stage 0. If you haven't done that in a while, after you put on a boost gauge and MBC and start playing with your wastegate, then you'll be coming back with these problems:
-"I installed a MBC but it only boosts to 8 PSI"
-"I'm getting a miss on cylinder 3 whenever I get on it"
-"My dipstick is smoking, what's wrong with my car"
Old May 17, 2010 | 08:23 PM
ahhhhh i see. alright. ill do that first thanks.
Old May 25, 2010 | 03:50 PM
ibified's Avatar
I'm in the process of doing that with my 850 wagon that I just bought. I did the cap/rotor/plugs/plug wires, have the PCV system sitting in the garage (gonna do this weekend I think), have about 25 ft of vacuum lines that I'm gonna replace when I do the pcv system, and have inspected most of my hoses. Once that's done, I plan to replace the wastegate diafragm and then add a manual boost controller along with boost and afr gauges.
Everyone here is right on about that though, you want to make sure that your car is mechanically sound before you start trying to throw more boost into it...also, when you DO add boost, expect random stuff to break, such as couplers, hoses, etc.
rspi
Sep 22, 2014 08:42 PM
CrusherCurtis
Nov 28, 2008 05:43 PM
green940turbobrick
Nov 15, 2006 01:55 AM
charlie brown
Jun 22, 2006 12:58 AM
cool_kyle_3000
Oct 18, 2005 07:31 PM
