850 Turbo won't start, and the engine fan has its period!
Old Dec 13, 2014 | 03:17 PM
AndreasReberg's Avatar
Unhappy 850 Turbo won't start, and the engine fan has its period!
Having a problem with a 97 850 low pressure turbo (175hp).
I'm currently running on the ECU from an 94 (obd1) 2.0 T5 (210hp) having no issues at all. It also runs fine with the original ECU, and with an ECU from an 95 (obd1) 2.3 litre T5 (225hp).
I also have an T5-R ECU from a 95 (obd2) T5-R. The ECU is chipped. My problem is that when I'm turning the key with this ECU the cooling fan in the engine bay starts blowing, even though the engine is cold. The engine turns, but it wont start. I guess that those two faults comes from the same cause, the ECU. Anyone having experience with this? I've also changed the immobilizer (?).
I appreciate all help I could get! I'm starting to hate my car. I have all the parts I need for a great set up, but it wont start.
Old Dec 14, 2014 | 01:16 PM
I'm so confused. Your post claims it runs fine with 2 different ECU's, why not use them?
Old Dec 17, 2014 | 07:48 AM
Psaboic's Avatar
Agree.....unless you are dead set on using the chipped ECU, just use one of the ones that work fine.
Old Dec 21, 2014 | 09:16 PM
boxpin's Avatar
In my experience with performance ECU's they turn on the fan when they are in programming mode. Mine have been from ARP and from TMM9, both had a switch on the top that when triggered would turn on the fan.
Old Dec 22, 2014 | 04:17 AM
Hey! Figured it out. Was going to try one original 2.3lite T5 chip instead of the trim-chip. Found out when I opened the ECU that 4 or 5 of the solder points had melted. I hope it was because of bad connection in the first place, going to get it soldered again and try it once more. If it doesn't work I'll just get another chip which fits the 4.3 system!
Old Dec 25, 2014 | 09:55 AM
Psaboic's Avatar
Good Luck. I hope that solves the issue for you
98S70fromTX
Aug 25, 2012 12:21 AM
jake2011rt
Mar 18, 2012 07:17 AM
04XC90T6AWD
May 16, 2011 06:08 AM
rfred
Nov 13, 2009 10:48 PM
Vineboydownunder
Mar 29, 2009 08:52 PM
