850 window- ready to burn this car!!!!!
Old Aug 10, 2010 | 07:33 PM
pdogi's Avatar
Default 850 window- ready to burn this car!!!!!
I have had this car(1993 850) for 4 years now. Mechanically it has been great- but all the small stuff has broken. My latest saga is this. One day recently i was rolling down the drivers window and for no apparent reason the window came off of the track and got stuck. Fast forward- i went to Volvo and bought 2 green window pivots and put them in. that didn't work so i assumed the regulator was bad. I went to the junkyard and took a regulator off of a 97 850 and put it in. I greased the pivots and tried the window and it seemed to work ok . Today(5 days later) I was rolling down the window-yes you guessed- the same thing happened. Now what do i do? It is a good thing there wasn't a can of gas nearby . Can anyone tell me why this happens????????????? I have already replaced a lot of stupid little stuff on this car including the odometer gear. I am getting tired of fixing this car!
Old Aug 11, 2010 | 01:47 PM
NCdad's Avatar
I own a 1995 850 GLT. I am going to have a similar porblem. My driver's window now makes a click sound as it reaches halfway down. It does not click at all going up. The click sounds like it comes from a 'gear tooth'. My temporary solution was to put a small piece of masking tape on the door where it clicks. I will not lower it beyond that mark until I find and fix the problem.
I will not buy any parts until I have searched the internet -- websites like this and called a mechanic at a Volvo dealer and discussed it. I will get as fully informed from people who know before I reach for my wallet. I do not yet know the solution to your problem or mine.
The mechanics at the Volvo dealership are nice, but they are at work and have other things to do. I respect that. I know I am asking for a favor so I prepare one or two quick questions before I call. I keep the call short and thank them sincerely and with great appreciation ! Try it.
Old Aug 11, 2010 | 02:08 PM
Bobec's Avatar
Check the window track on the back side of the door. There is a screw with a finish washer that holds it in place. To get to it you need to remove the door latch which is a bit of a pain.
The reason I say this is while I was replacing my door latch I noticed that the lower tab that holds the track in place was broken and the track was only held at the top. I removed it and saw that this tab had been welded once before and the new weld broke too. Just an idea but who knows? good luck.
Old Aug 11, 2010 | 06:37 PM
fcpgroton's Avatar
Former Sponsor
I don't think it is anything other then what was mentioned above. I had this same issue on my 240 and I had to bend the track to get the window to go up and down correctly. It really does sound like it is falling off the track for sure.
Sunshine
Jan 30, 2012 11:10 AM
jorgeaiello
Sep 6, 2010 04:23 PM
Keith Tobberman
Aug 9, 2008 11:35 AM
cbrack
Jul 5, 2008 09:07 AM
Lecter
Jul 21, 2007 10:44 AM
