850R been sitting for 4 years.
Old Mar 31, 2018 | 11:48 PM
SirTophamHat's Avatar
Default 850R been sitting for 4 years.
Just bought a 1997 850R with 160,000 miles that hasn't ran or been cranked in 4 years. Im going to put fogging oil in the cylinders and do an oil change as well as siphon out the old gas. What other things should I do before I attempt to crank it? im particularly worried about making sure the turbo is lubricated
Timing belt, tensioner and idler pulley was changed 5 years ago and only has about 10,000 miles. I'm not sure how cracked or worn it is having been sitting for so long.
Old Apr 1, 2018 | 01:13 PM
tryingbe's Avatar
Takes one minute to take the upper timing cover of to check the condition of the timing belt.
Old Apr 2, 2018 | 08:21 AM
860ARE's Avatar
Definately oil change and new gas . I wanted to know if my turbo was getting oil so i cracked the banjo bolt be into the turbo.haha lets just say it was working fine. . Check the belts for cracks and make sure coolant is full. That should be good to just start.
Old Apr 6, 2018 | 12:22 AM
Welcome to VolvoForums SirTophamHat
Fresh gas and a filter.
Check the timing belts condition.
Pull the ignition coil wire from the distributor and ground it. Pull the fuel pump fuse to keep from flooding the engine and then crank the engine over. Do it a few times for a reasonable period of time. Don't want to cook the starter. That will build oil pressure and lube all the bearings and the turbo.
Plug in the coil wire, fuel pump fuse and give it a shot.
I'd do the oil after I got it started and running and warmed up a bit.
Attached Thumbnails 850R been sitting for 4 years.-tumblr_mk2r0zcizh1r5wnj1o1_500.gif
Old Apr 6, 2018 | 07:48 AM
firebirdparts's Avatar
The lifters will take about 15 minutes to quiet down, but don't let that scare you.
Old Apr 6, 2018 | 09:59 AM
I forgot about that. Don't rev it, just let it idle and heat up. I remember I let mine sit for a few weeks (months?) and when I started it up it rattled like crazy at first. Sounds like the engines going to rattle apart. It's funny how you forget little things like that and then the memory of it is like yesterday once you're reminded.
inkydink
Dec 31, 2013 02:09 PM
Dru Morgan
Feb 28, 2013 08:47 AM
Ed_F
Apr 18, 2011 10:58 AM
rspi
Apr 4, 2011 06:04 PM
ttgxc
Jun 22, 2009 11:01 AM
