850R ECC stuck on defrost.
check out volvotips.com for some diagnostics suggestions. Any ECC fault codes like a blinking AC or REC light etc? Could be the blend door motor may have disconnected from the rod to the door. can you hear the motors actuate when you change air flow selections?
