Defrost/foor vents isn't blowing air
Old Nov 29, 2013 | 06:48 PM
DNiefer's Avatar
Default Defrost/foor vents isn't blowing air
96 Volvo 850 GLT-Defrost air vent isn't blowing out when I turned selector(control ****) to defrost but always both sides and middle vents blowing not defrost or under dash(floor) vents though I already replaced blower motor and resistor. Speed control and temp(heat/cold) works fine. Changed to different choices but seemed the same, I guess.(it's manual) What will I need to do? Thanks and appreciate!
Old Nov 29, 2013 | 10:17 PM
97black850's Avatar
i have heard that the plastic arm can break that controls the mechanism to switch between areas
Old Nov 29, 2013 | 10:27 PM
You'll need to pull the head and see if everything is connected and if so follow the cables and see if anything at that end is disconnected or broken.
Hamilton65
Jul 29, 2015 11:06 AM
Spyros
May 22, 2014 11:37 PM
IFGD
Sep 27, 2011 10:03 PM
ryan29121
Oct 29, 2010 04:32 PM
