850R ECC stuck on defrost.
Old 02-20-2019, 11:15 AM
860ARE's Avatar
Default 850R ECC stuck on defrost.
hello. Anyone have any ideas on how to get the heat adjust to move from defrost? Temp and speed settings work it just stuck on defrost.
Old 02-20-2019, 07:43 PM
when you say stuck on defrost, are you referring to the **** itself or that no matter what you dial up, air only comes out of the defrost vents?
Old 02-20-2019, 09:03 PM
860ARE's Avatar
Only air on defrost vents. The **** turns fine. Im glad it stuck on defrost atleast being 5 deg outside but i want it back to adjust.
Old 02-21-2019, 03:55 PM
check out volvotips.com for some diagnostics suggestions. Any ECC fault codes like a blinking AC or REC light etc? Could be the blend door motor may have disconnected from the rod to the door. can you hear the motors actuate when you change air flow selections?
Old 02-21-2019, 04:33 PM
860ARE's Avatar
I had ECC codes for years never checked them. I don’t hear the motor engage
Old 02-22-2019, 02:28 PM
volvotips.com has a 850 diagostics page that may help. The ECC code will tell you if the motor is the issue.
Old 02-22-2019, 03:08 PM
860ARE's Avatar
Thanks
Ghent
06-26-2016 04:59 PM
HellCreek
11-17-2015 09:46 AM
DNiefer
11-29-2013 10:27 PM
eurotrash
12-11-2008 01:25 PM
SlavaD
09-20-2007 11:00 AM
Quick Reply: 850R ECC stuck on defrost.
