850T trailing arm end link mount damaged
Old Dec 22, 2016 | 12:01 PM
Default 850T trailing arm end link mount damaged
took the 850 into the shop for a broken right rear trailing arm end link bushing and was told the mounting point to the subframe for the end link is damaged and will need welding to repair (nothing to hold the bolt?). I have a replacement for the end link (#65431284) and a mounting bracket (#3516122) but was told there still needs some fabrication/welding. Any one every come across this? Will be retrieving the car later and will post some pics then. Off to a welder tomorrow I guess.
Old Jan 14, 2017 | 07:42 PM
wound up taking the car into a body shop for the welding. they fitted some new metal and welded in the new bolt. New end link bolted in cleanly and the car drives true - but it took about 6 hours of shop time... They also reinforced the other side - as I think the worn end link accelerated the rusting. Something worth inspecting on other "northern" 850s.
Chebucto
Mar 24, 2020 06:19 AM
grigalid
May 6, 2011 12:02 PM
jrmcgove
Oct 30, 2009 11:18 PM
VTBricked
Jun 24, 2009 08:15 PM
fv15
Oct 23, 2006 06:33 PM
