93 Volvo 850 Camshaft Position Sensor
Old May 19, 2011 | 08:49 PM
rcpaq13's Avatar
Default 93 Volvo 850 Camshaft Position Sensor
My 1993 850 GLT has started to run poorly. It idles roughly, acceleration is delayed, throttle response is slow, power drops of at 3000 RPM but returns at about 4000 RPM. Engine error code is 3-1-4 which indicates " Camshaft Position Sensor signal is Absent". If I disconnect the camshaft position sensor the engine stalls and won't restart. If the sensor is bad why does the car run? Is there any way to test the sensor. If this isn't the problem any ideas?
Old May 21, 2011 | 03:41 PM
MattyXXL's Avatar
When was the last time you did a stage 0?
Jiveturkey31
Jul 24, 2009 08:36 PM
Volgrrr
Feb 9, 2008 09:39 PM
howardvu
Sep 18, 2007 08:23 AM
GaryBrad
Jul 7, 2007 12:42 PM
pistolero45e
Aug 16, 2005 01:09 AM
