'94 850 sedan -no start-
Old Jan 2, 2007 | 07:27 PM
new2850's Avatar
Default '94 850 sedan -no start-
I have a 1994 850 sedan (non-turbo) that will crank but not start. I can smell gas. Have replaced cap and rotor. Checked resistance on the coil (should have range of 8-9 kilohms -reads 7.90). Have spark to rotor cap. shows no fault codes on the A2 (1-1-1). Any suggestions? Thanks.
Old Jan 2, 2007 | 07:50 PM
JPN's Avatar
JPN
Default RE: '94 850 sedan -no start-
Hello Mr. new2850,
Greetings from Chicagoland.
Of the basic 3 requirements for an engine;
1. Good spark
2. Good fuel supply
3. Good compression
1 & 2 seem fine, so it could be either #3 (loss of compression) or faulty camshaft position sensor. Now, have you checked the ignition wires & spark plugs? I wonder if the fuel pump is playing tricks also, even though you smelled fuel.
Have you tried flooring the accelerator pedal & cranking? If not, try it to see if the engine responds. Also, please provide us with any additional info you might have noticed.
Happy New Year,
JPN
Old Jan 2, 2007 | 09:23 PM
JimKW's Avatar
Did it stall and then just not restart, or has it been hard to start for a while? It could be so many things, it's hard to tell with very little information.
Old Jan 2, 2007 | 10:49 PM
new2850's Avatar
I had no other problems with the car before this. It always started fine.
Old Jan 3, 2007 | 08:48 PM
Check for injector pulse.
240wagonPHL
Apr 18, 2015 10:47 AM
techmantrey
Feb 6, 2015 03:19 AM
blackstonehere
Jan 28, 2013 08:21 PM
gogomom
Jan 9, 2013 07:08 PM
Zoidbergsvolvo
Nov 1, 2010 09:51 PM
