94 850 transmission no reverse
Old Apr 7, 2014 | 09:28 AM
Catimann's Avatar
Default 94 850 transmission no reverse
The girl friend called that the car was driving funny, shifting weird. So I drove over and we tried it out. I was trying it out while she was in the store and it wold drive forward in reverse! Shifting felt like it was confused. She limped it home and I took it to my house this morning.
Yesterday she was sure she saw a "flashing arrow on the dash for a time" but there was none last night and the reverse lights have been working.
I tried the 20x cycling of the shift lever to get a temp fix of any kind, no use.
I drove it to my house this morning and once in my driveway (and I may need to become religious here) I lost all the gears. Just before that coming down the road (in the rain) it shuddered a bit and the tires chirped a few times. Almost like they had stopped for a split second.
Now I have a flashing arrow and need to figure out how to check that code.
I will get back with that info.
From the A1 port I have a 2-3-2 code
Well a no speedo signal is a waste of time.
Based on the other info I have read last night and at Volvospeed where this was stated: "The requirement to replace the PNP switch is usually prompted by the up arrow on your instrument cluster flashing" This is my next step.
Old Apr 7, 2014 | 10:37 AM
What have you done? Have you checked the fluid level? Have you changed the fluid?
There is a good chance that the PNP switch is going out. The rolling shifter thing doesn't always work.
Old Apr 7, 2014 | 11:05 AM
Catimann's Avatar
Thanks rspi, can always count on you. I used your video to brush up on how to check the codes.
Tranny fluid is new last year & level is good. I was just out there again and attempted to move it. Same deal as before but at least the thing moved. So I got in into position to work on and will take out the PNP now.
Ok got it out and ordered a new one. Found the trans dip stick holder could be played with and not totally removed. The sheet metal bends a bit. I did not remove the air box hold down and had no issue getting out the PNP.
I see it has adjustable placement and was wondering how that was done?
Paul Lott
Jul 16, 2014 05:40 PM
msbizz
Apr 4, 2008 12:55 PM
msbizz
Mid West
Apr 3, 2008 05:19 PM
burkem
Sep 29, 2005 02:47 PM
