1994 850 Transmission -no reverse & compatiable replacement
Old Jul 16, 2014 | 05:40 PM
Paul Lott's Avatar
Wink 1994 850 Transmission -no reverse & compatiable replacement
A little history..
We pulled motor/trany for RMS, also had sketchy S1 code intermittent. Replaced S1 and lock up solenoid. Motor/trany installed and topped off fluids. Had to deal with a idle issue but resolved after a few days. During that issue did drive a little and trany seemed fine. Last test drive after fixing idle issue it seemed that at 45-50 trany did not go to a higher gear, rpms seemed a tad high. Next day no reverse, nothing led me to think this would happen
Transmission is a 50-42LE
-PNP was new a few months ago, was checked and adjusted to no evail
-No codes thrown, may not have driven enough
-Did find bad trany speed sensor, replaced with used, no change
- New fluid, not low
Research found seems everyone says its a gonner but I tought I would ask for another opinion before I decide to replace.
I have yet to find a good database on what years/models I can pull a compatible transmission from, below are a few I found in the junk yard when getting my speed sensor. Is there a list of compatible models?
Year - Model - Mileage - T Model# - T Serial #
1997 850 118k, 1208892 96688978
1996 850 222k 1208818 95JW92620
1997 850 208k 1208892 96G93385
1999 V70 ??? 12088889 99AW521444
My trans is
1994 850 185k 1208776 930W90226
jeffrisley
Jun 14, 2015 01:48 PM
Catimann
Apr 7, 2014 11:05 AM
pchow138
Nov 30, 2010 05:51 PM
danielcash
Aug 27, 2010 10:44 PM
huzzsaba
Apr 2, 2009 05:35 PM
