94 850 TURBO MISS
Old Aug 20, 2006 | 11:38 PM
JIMBO12's Avatar
Default 94 850 TURBO MISS
HELLO, IVE GOT A 94 850 TURBO THAT WAS RUNNING PERFECT, THEN ONE MORNING WHEN I STARTED IT UP IT REVED PRETY HIGH FOR A FEW SECONDS THEN WENT TO NORMAL. IT ALSO DEVELOPED A SLIGHT MISS AT IDLE. THE ENGINE LIGHT CAME ON A FEW DAYS LATER SO I CHECKED THE CODES AND A TON OF THEM CAME UP. THE CODES WERE 514,545,555,225,543,451,452,455,232,512. I HAD JUST REPLACED THE AC COMPRESSOR A WEEK AGO. DID I PULL A HOSE OR LINE FREE IN THAT AREA? ANY HELP WOULD BE GREATLY APPRECIATED. THANKS
Old Aug 20, 2006 | 11:56 PM
Default RE: 94 850 TURBO MISS
Which ports did they come from?
Old Aug 21, 2006 | 11:13 PM
JIMBO12's Avatar
I PULLED THE CODES FROM A2. THANKS
Old Aug 22, 2006 | 12:00 AM
The Majority of those codes are Missfire codes.
Has it had a tune up lately?
http://www.troublecodes.net/Volvo/
Also check out that site for the Codes.
If you look at the Wires from the Dist. If they are Volvo look for either White or Yellow Numbers stamped on the wires. That is the Date they were made.
Old Aug 22, 2006 | 02:03 PM
JIMBO12's Avatar
THANKS FOR THE INFO. WHAT WOULD CAUSE THE ENGINE TO REV UP AT STARTUP LIKE IT DOES. IT REVS PRETY HIGH FOR ABOUT 5 SECONDS THEN IDLES DOWN. ANY GUESS?
Old Aug 22, 2006 | 09:29 PM
Exactly what RPM does it go to?
If the codes are still stored in the system then the Computer might be doing it.
Old Aug 22, 2006 | 09:50 PM
JIMBO12's Avatar
IT WILL REV TO ABOUT 2000 TO 2300. I HAD CLEARED THE CODES ONCE ALREADY. ANY IDEAS? THANKS
Old Aug 22, 2006 | 09:55 PM
It will usually rev to about 1500 or 1600 on start up but that seems to high.
Any Vaccum leaks at all?
sparkmaster1
Jul 17, 2014 04:19 PM
knitter66
Jan 24, 2011 12:39 PM
Saleen9090
Mar 22, 2009 06:02 AM
pconfar
Dec 27, 2007 05:39 PM
s40volvoH
Mar 18, 2005 06:43 PM
