94 850 Turbo rough idle at stop
Old Aug 15, 2013 | 10:47 PM
97black850's Avatar
Default 94 850 Turbo rough idle at stop
Hello,
I just replaced the PCV on my 94 850 Turbo. I am 99 percent sure I have all lines and hoses connected correctly. The problem is that whenever I drive the car, it almost wants to stall out when slowing down and especially at a stop. It doesn't seem to change when I shift to neutral. Also, it doesn't seem to matter if the car is at operating temp or still cold.
Old Aug 16, 2013 | 01:09 PM
BFR's Avatar
BFR
Originally Posted by 97black850
Hello,
Did it behave like that before? If not you obviously didn't install everything correctly. This could be a vacuum leak, intake manifold leak, or something else. I'd start by checking for leaks in these areas. A smoke test is best but if you spray carb cleaner on an affected leaking area the idle will change. Also, is it setting off a CEL?
Old Aug 16, 2013 | 01:20 PM
MattyXXL's Avatar
did you re connect your maf?
Old Aug 16, 2013 | 08:58 PM
BFR's Avatar
BFR
That would definitely set off the CEL, LOL! Of course, maybe his CEL bulb's burned out and he's really in the dark here, who knows?
In any case, it's obviously something he either didn't reconnect, didn't connect or fit right, or just left off during the job.
Old Aug 16, 2013 | 11:54 PM
97black850's Avatar
Didnt do it before, MAF is reconnected, read codes and got nothing.
Old Aug 17, 2013 | 07:09 PM
97black850's Avatar
something else i noticed. the car wont build full boost unless I unplug the tcv then replug it in will build full boost. is this the computer compensating for the possible air leak? and for some reason the A6 port on my box doesnt work so no way to read those codes...
Old Aug 19, 2013 | 08:34 AM
97black850's Avatar
is there anything else besides a vacuum leak that could cause this?
nkinkade
Feb 28, 2014 08:49 PM
zangado1
Sep 10, 2012 08:48 AM
pnhons
Nov 20, 2011 05:26 PM
rosesforlily
Nov 5, 2009 09:23 AM
yank50
Mar 14, 2009 11:15 AM
