odom not working
Old Aug 20, 2013 | 08:48 AM
bbiljah's Avatar
Default odom not working
which gear do I need or is it a shot in the dark without looking.. Cause one is $20 and the other $30 from ipd.
Old Aug 20, 2013 | 08:52 AM
I believe one is for the trip and the other is for the main gear.
Old Aug 20, 2013 | 09:01 AM
bbiljah's Avatar
on ipd they both say odom O.o
Odometer Supplemental Gear
and
Odometer Gear
Product Search: INSTRUMENTATION
Note: my speedo also does not work.. I think its the Control madual cause my tracs light is on.
Old Aug 20, 2013 | 10:08 AM
Likely the ABS module, www.MidWest-ABS.com
Old Aug 20, 2013 | 10:12 AM
bbiljah's Avatar
Can the abs module make the odom not work? I thought it was off a cable and gear.. This is my first volvo so some of the things on a volvo I'm not used to.
Old Aug 20, 2013 | 10:46 AM
MattyXXL's Avatar
A year make and model will help.
You can run a cluster diagnostic if your 95 or earlier
96-98 then the abs module will be the cause of your speedo and tracs
your odometer issue is most likely the main gear no the supplimental but Id replace them both while you where there
Old Aug 20, 2013 | 10:47 AM
bbiljah's Avatar
it's a 96 volvo 850 wagon
Old Aug 20, 2013 | 10:54 AM
MattyXXL's Avatar
Yeah you have 2 different problems.
Your speedo and your tracs/abs if from the module.
Buy one from Matt and send yours back when you get the new one installed Rob supplied you the link above
The odo is the gear
like i said its most likely the primary gear, but ive seen both stripped.. so I would get both.
There are other places to get them that are cheaper too..
Old Aug 20, 2013 | 11:15 AM
MattyXXL's Avatar
Wait I just noticed the same screen name on FVC? Is that you? Are you from FL?
Old Aug 20, 2013 | 11:26 AM
bbiljah's Avatar
Yes sir, I live in edgewater about 20 mins south of Daytona beach
Reefers4U
Jun 22, 2013 11:07 AM
cgreygoose
Jan 5, 2013 10:04 PM
dallasmenard
Nov 29, 2010 04:40 PM
pumahitman
Oct 14, 2010 04:21 PM
BigAdam
Oct 21, 2008 10:01 AM
